Atos Consulting
Last activity: 17 Feb 2021 10:12 EST
Mobile client and offline-enable cases seem to cause a problem
When I start an application on the mobile client (Pega 8.1, iOS, mobile Proprietary information hidden) it starts well if the application does not contain cases that are enabled for offline use. But if we enable one case type for offline use, we cannot login to the application: after submitting user credentials we are thrown back to the opening screen of the mobile app with the url.
Ajay Pittampalli Feba Roy SaiChand Sunkara Sandarsh TB Tondapu Praneeth Chowdary and 36 More -
PL
Let me paste the instructions again. This time I'm reattaching the images right from my hard drive:
iOS: Viewing logs with Xcode
- Open Xcode and select Window->”Devices” from the menu (CMD+Shift+2):
- Select connected device:
- Install application on the iOS device. You may also download ipa file and "drag and drop" it to "Installed Apps" area of "Devices" window (you can also choose "+" and browse the ipa file):
- You may need to click "arrow" button to show the device console:
- Start installed application on the device and see logs:
- You can delete or save the console using buttons in bottom-right corner:
PL
Please make sure your application conforms to https://community.pega.com/knowledgebase/articles/offline-mobility-guidelines-0. Please share mobile application logs so that we are able to help further.
Atos Consulting
I have checked and it seems that I conform to the guidelines mentioned.
How can I get the mobile application logs for iOS? I've seen a post for Android, but not for iOS.
PL
Please refer to Apple support pages to learn how to read iOS application logs. For your convenience, I'm attaching a copy of our internal instructions:
Atos Consulting
Thanks. You refer to picture in PegaMesh that are "restricted" so I cannot access them.
I see that notifications are not supported in the Pega Mobile Express app. Could it be the case that the same holds for working offline? Because that may provide an explanation....
Kensho Tsuchihashi Dhanasekar Srinivasan Avik Mitra Suresh mani Cloe Walker and 2 More
PL
