Robotic Automation Smart Shape with Validation rule defined gives unexpected results
I have a work type with an embedded Robotic Automation (RPA) using the "Assign to robot queue" smart shape. The configuration of the smart shape allows you to define a Validation:
Based on the smart shape's flow should cause the flow to return a result Fail:
Instead, the flow returns to the "Complete Automation" assignment as shown in the above flow marked up with a page message.
Is this as intended or should the flow follow the path defined??
