Comm from PegaReach clients to PegaSYSTEM upgraded with TLS 1.2
As we are trying to have the communication between Pega Reach clients to PegaSYSTEM upgraded with SSL(TLS 1.2), Please let us know if you have any configuration changes which you can suggest us for the same.
And while going through few pega instance folders on the server found the file ($PEGA_INSTANCE/SDK/SOAP/ssl.txt) which suggests some configuration change for implementing SSL between client and server. Please confirm if the below configuration(listed below as found in the ssl.txt) would work for the SSL communication between Pega Reach clients and PegaSYSTEM or if you have any latest updates which we could try configuring.
Pega Reach : 6.6.2
Pega System : 8.1.6
Java : JDK 1.6
OpenSSL : 1.0.2k
JSSE : JDK 1.6 (JSSE is part of the JDK)
***Updated by moderator: Lochan to update platform capability***
