I can't see the new saved changes after the first run..
I've been going throw some issues lately, every time I make some changes in the UI
(ex. I added a text label)
and when I click save and run on the case it wont show..
When you run it once it would stay with the last saved changes.. I can't see the saved new changes after the first run.. I checked their visibility and it is set to "Always".
If this is a common problem and if there are any troubleshooting I need to follow to fix this, I will appreciate it.
Thank you!
***Updated by moderator: Lochan to update platform capability***
