Corporation Service Company
Last activity: 24 Sep 2018 12:51 EDT
I can't see Configure Alternate stages
Hi Chiranjeevi
I don't see the configure alternative stages option at all in Action tab. may I know where I am going wrong. see the attached screenshot. right now I am learning pega and doing assignment 'Adding alternate stages to the case life cycle'. I can mover further from this step.
Thanks.
***Moderator Edit: Vidyaranjan | Moved from PSC to Academy***
EPAM Systems, Inc.
ES
Hi Asif,
I don't have any idea about steps you described above to RCA. I am new to Pega and learning System Architect Essentials. Right now I am in the middle of the course. I am here at stage of course as shown in the screen shot. At this step of the course, I have to Configure the Alternate stages in the Exercise. But I couldn't see that in Pega express of exercise application. Please let me know where can I configure that as per the exercise.
Ram Putta
Techmahindra
HI,
I am also facing same problem. I can't see configure alternate option.
Can some one please help us as we are new to Pega.
Thank You,
Ranjeet
Zensar Technologies Ltd
Facing same problem. Please help
Bits in Glass
You will see these steps only when you go to the Cases.
Follow these steps below.
launch the Developer Portal >> From the Left Side, Select Cases >> Now select any case type which you already created >> Now you will see the option Configure Alternate Stages.
Please let me know if it resolves your issue or not.
Srinivas Bonthu
Sun Life Financial Inc
Sorry that option doesn't seem to exist. We are given Pega Express not Developer Portal just for clarity.
We go into Cases and then select the expense type we've been building and there is no Configure Alternate Stages option on any of the tabs provided
Ok issue solved.
Bottom lefty corner there is a double arrow symbol. This moves you from Pega Express to the full Pega Designer Studio which solves the issue
