Clocklike Minds
PL
Last activity: 25 Sep 2018 5:26 EDT
Problem with an activity after persisting a case
Dear Community,
As title says, I have a problem with a flow, where I have a utility shape right after "Persist case" shape.
In that utility shape I have an activity which one of steps is to put pzInsKey of the case in a custom property. And the problem is that each time that property is empty. When the process stops on next assignment, I can see that Case's pzInsKey is set and my property is empty. Tracer is "clean".
When I modify the flow and put an assignment between utility shape and "Persist case" everything works ok.
Does anyone had similar problem or/and know the solution for that?
