Merkle
Last activity: 19 Sep 2018 10:35 EDT
Report Definition with 50K records
We have reference data with 50K+ rows and need to compare only one row with primary key match at one time. Currently we use report definition to fetch the rows and a datapage at node level to read the row. Is this an efficient way to do this? Would an activity with obj-browse be better? Is it ok to keep 50k+ records in memory? Also, how to use the parameter from data page to report definition to fetch only one row?
Mastek
Hi
Two things here :
1. Your current approach should be fine.
2. You must be using this Data Page in some rule to fetch the details. Then how do you plan to generate the Primary key for that one record initially?
Or do you have a segregation based on Reference Data Type in your table?
You can surely achieve the parameterization with either of Options in Point 2. Confirm on that and then we can see what configuration to make.
Regards
Bhavya
Merkle
Hi Bhavya,
Thanks for replying.
So, to confirm, you think its not a issue with having such a large number of records in memory?
Because one thought is, this might have an impact on performance. Why do you think this should be ok? Please let me know.
Secondly, the reference table stores a list of all location details with locationcode as PK. We are getting this locationCode in the incoming json request that we can pass as parameter. Hope that helps you with your question.
Thanks!
-Hansa.
Mastek
Hi
When you say memory you mean "Clipboard" , if yes then thats not the preferred way to load 50k records at once.
Wherever you have to use Location details you can refer you data page as D_LocationDetails[LocationCode: <Value>] and in the report definition have location code as parameter and is "Equals" in comparison.
Regards
Bhavya
Merkle
Thanks. Will try out that approach.
Tata Consultancy Services
Can you try key page access ?
Merkle
Can you please elaborate. Not sure what you mean by key page access? Is it the setting in data page? Then yes, that is selected.
have you selected that ?
Merkle
Yes, that is selected. My only question is from a performance point of view, this setup is ok or is there a better way to do this?
Felix Soto
Please refer below article,here they have clearly explained about it.
Vinay Reddy
ANZ Banking Group Ltd
Hi Hansa,
I would recommend using a data page of structure page because you are expecting only one output every time and source as lookup as you know the primary key of the record.
The scope can be a thread level as per your scenario.
With this approach, you will load each record as per need.
