Capgemini
BR
Last activity: 25 Apr 2019 7:17 EDT
Flow_MissingFlowName
I',m trying to create a new case in QA environment but this error "Flow_MissingFlowName" doesn't stop to appear.
In dev environment, this error doesn't occur.
I already ready this article about the error and tried to save another version of the pydefault rule but the error stay.
Please anyone can give some tip how I can resolve this problem?
Try this:
Save the CaseType and FlowRules into higher version.
Adaps
Could you please save the flow rules to higher version and check it once
Please do save the flows to higher version and also do save the case types and check :)
Andrea Loris Gialain
Capgemini
BR
Hi SusanLiu and guys
I have found a flow which was circumstanced and the base version was corrupted.
But I don't understand why the problem doesn't occur in the dev environment.
CollabPartnerz
so now you withdrawn that circusmstance rule or how you resolved your issue.
Capgemini
BR
Sure here what I have done:
I have turned off the draft mode and made a new save as in the higher version.
CollabPartnerz
okay, thank you antonio.
Capgemini Nederland BV
Hi everyone,
I am facing the same problem of "Flow_MissingFlowName".
Save as of the case type and the flow rules to higher version does not help.
Is there any other way this can be solved?
Thank you for posting your query in the PSC. This looks like an inactive post and hence, we suggest you create a new post for your query. Click on the Write Post button here. Once created, please reply back here with the URL of the new post.
