Sopra Steria
CH
Last activity: 16 May 2019 10:23 EDT
Pega DSS - Overview/Description
Hi
I’m looking for an Overview with descriptions for the Pega Dynamic System Settings and a way how I can get some information from the System, which changes can bring an positive effect to the performance.
Regards
Thomas
PL
Standard DSS settings are given in the help at https://community.pega.com/sites/default/files/help_v731/zstandarddata/data-admin-systemsettings.htm
This help also says "Consult the Configuration Settings Reference on the PDN for additional details on specific Dynamic System Settings instances."
The document can be located at: https://community.pega.com/system/files/pdfs/ProductSupport/Products/PegaRULESProcessCommander/documents/PRPC/V6/602/ConfigSettingsReference0602.pdf
Some of the more recent settings (e.g. those added in 7.x) were not present in 6.2 and are therefore not included in this doc. Unfortunately, there isn't a newer version of the doc with 7.x settings in it but it is possible to locate **most** settings on the community area by searching.
For example:
Pega-RulesEngine MultiTenant (for Pega-RulesEngine MultiTenant/xyz)
https://community.pega.com/support/support-articles/multitenancy-tenants-unable-access-shared-data-instances
For Pega-SearchEngine indexing/xyz
https://community.pega.com/knowledgebase/articles/troubleshooting-elasticsearch-common-issues
and
https://community.pega.com/sites/default/files/help_v731/procomhelpmain.htm#engine/search/eng-search-dss-tsk.htm%3FTocPath%3DSystem%2520management%7CFull-text%2520search%7C_____13
Pega-RulesEngine reporting/useLayerCakeSchemaChanges
https://community.pega.com/support/support-articles/pzwarningsintroduceddoactivity-rule-obj-report-definition
Dynamic System Settings for application security
https://community.pega.com/knowledgebase/articles/dynamic-system-settings-application-security
High Availability Administration Guide (for Pega-ProcessEngine session/ha/crash/xyz)
https://community.pega.com/system/files/pdfs/Pega%207.4%20High%20Availability%20Administration%20Guide.pdf
PL
Please find more information about DSS in below location:
and
Please let me know if you have any question related to this topic.
Piotr
Areteans
To be simpler, if any value is specific to any environment then you can create a DSS.
As this is data instance, it is not locked and even easy for business people to change.
Hope this answers your question.
Divya Sri Padarthy
Udit Verma
CollabPartnerz
If the to be changed based on business frequently then its better to go with DSS.
CollabPartnerz
Sopra Steria
CH
Thanks for the Answers. What I need is the following
I've have for example the DSS prconfig/conclusioncache/rulefilebinary/minimumsize/default
What I need is the description for the System Setting itself, what does it in the engine?
What is the best way to get the correct Value of the DSS.
We can do it via Load and Performance Tests, where we chance the Cache Size, but this will be very time consuming.
I'm locking for a way where Pega tells me, how the Chache is used and what will be an value which fit's better.
I don't need a description what DSS means ;-)
Regards
Sopra Steria
CH
Hello All
Here ist the complete list of Pega DSS in our Environment.
Can somebody give me a description of the DSS?
Possibilities to Check somewhere in Pega if the DSS for Caching for example are set correctly?
There are other DSS which can be applied to improve the Performance?
Many Thanks
Thomas
OWNING RULESET |
SETTING PURPOSE |
Pega-Engine |
prconfig/asyncservices/enable/default |
Pega-Engine |
prconfig/crypto/onewayhashalgorithm/default |
Pega-Engine |
prconfig/database/storageversion/default |
Pega-Engine |
prconfig/initialization/displayExceptionTraceback/default |
Hello All
Many Thanks
Thomas
OWNING RULESET |
SETTING PURPOSE |
Pega-Engine |
Pega-Engine |
Pega-Engine |
Pega-Engine |
Pega-Engine |
prconfig/initialization/explicitTempDir/default |
Pega-Engine |
prconfig/initialization/persistrequestor/default |
Pega-Engine |
prconfig/initialization/rebuildlocalcachesonnodestart/default |
Pega-Engine |
prconfig/initservices/dnode/default |
Pega-Engine |
prconfig/initServices/initEmail/default |
Pega-Engine |
prconfig/initServices/initFile/default |
Pega-Engine |
prconfig/initServices/initJMS/default |
Pega-Engine |
prconfig/initServices/initMQ/default |
Pega-Engine |
prconfig/pradapter/logginglevel/default |
Pega-Engine |
prconfig/session/ha/crash/recordworkinprogress/default |
Pega-Engine |
properties/com.pega.pegarules.bootstrap.codeset.version.Customer/default |
Pega-Engine |
session/ha/quiesce/passivationTimeout |
Pega-RulesEngine |
fua/minimumAgeToPurgeFromDatabase |
Pega-RulesEngine |
fua/purgeAgeInDaysForRulesInLogUsage |
Pega-RulesEngine |
MultiTenant/InstanceVisibility/TenantOnly |
Pega-RulesEngine |
reporting/enablestatistics |
Pega-RulesEngine |
reporting/enablestatisticsForEmbeddedReports |
Pega-ProcessEngine |
session/ha/crash/EnableUserNotification |
Pega-RulesEngine |
reporting/reportstatistics/cachesize |
Pega-RulesEngine |
reporting/reportstatistics/minimumDaysToPurgeFromDatabase |
Pega-RulesEngine |
EventsRetentionPeriod |
Pega-RulesEngine |
fua/maximumApplicationsToPurge |
Pega-Engine |
prconfig/agent/enable/default |
Pega-RulesEngine |
MultiTenant/InstanceVisibility/TenantCannotOverrideShared |
Pega-RulesEngine |
MultiTenant/InstanceVisibility/TenantCanOverrideShared |
Pega-SearchEngine |
indexing/distributed/host_node_monitoring |
Pega-Engine |
prconfig/identification/cluster/name |
Pega-SearchEngine |
indexing/distributed/batch/numworkers |
Pega-SearchEngine |
indexing/distributed/batch/workqueuesize |
Pega-SearchEngine |
indexing/distributed/batch/requestbatchsize |
Pega-SearchEngine |
indexing/distributed/attachmentcharacterlimit |
Pega-SearchEngine |
indexing/distributed/queue/maxrecords |
Pega-SearchEngine |
indexing/distributed/search_timeout_millis |
Pega-Engine |
Timeout/page |
Pega-Engine |
Timeout/thread |
Pega-Engine |
prconfig/initialization/maximumfileuploadsizemb/default |
Pega-RulesEngine |
reporting/useLayerCakeSchemaChanges |
Pega-Engine |
prconfig/appcentric/shortcutsmru/instancecountlimit/default |
Pega-Engine |
prconfig/cache/instancecountlimit/default |
Pega-Engine |
prconfig/collections/mru/dependentrulesetlist/instancecountlimit/default |
Pega-Engine |
prconfig/collections/mru/propertyreference/instancecountlimit/default |
Pega-Engine |
prconfig/conclusioncache/rulefilebinary/minimumsize/default |
Pega-Engine |
prconfig/declaratives/fragments/instancecountlimit/default |
Pega-Engine |
Timeout/application |
Pega-Engine |
Timeout/browser |
Pega-SearchEngine |
indexing/distributed/search/fuzzy/enabled |
Pega-SearchEngine |
indexing/distributed/search/fuzzy/fuzziness |
Pega-SearchEngine |
indexing/distributed/search/fuzzy/max_expansions |
Pega-SearchEngine |
indexing/distributed/search/fuzzy/prefix_length |
Pega-SearchEngine |
indexing/distributed/search_enabled |
Pega-UIEngine |
pyMaxrecentrecords |
Pega-SearchEngine |
indexing/distributed/enabled |
Pega-SearchEngine |
indexing/distributed/index_enabled |
Ruan Malan
There aren't DSS settings or numbers that can be tweaked to improve general system performance. Only after proper analysis of what is impacting the performance, either done by GCS staff or certified consultants, changes or additional DSS may be recommended.
PL
For example:
and
