Humana Inc
Last activity: 24 Aug 2018 8:16 EDT
Devops Deployment Manager Issue in 7.3.1
Getting Error on click of Generate build in 7.3.1
Task execution started for task type: publish
Request object: {
"pxObjClass":"Pega-Int-Pipeline"
,"pyApplicationName":"Apex"
,"pyApplicationVersion":"01.22.01"
,"pyBuildArtifactName":"Apex_012201_1.zip"
,"pyCallBackURL":"http://louappwdl07s01:80/prweb/PRRestService/cicd/v1/task/publish/status?FlowName=pzPublishRAP&FlowActionName=pzPauseTask"
,"pyDoPackage":"true"
,"pyID":"PEGA-PIPELINE-CD APE-9"
,"pyProductName":"Jenkins"
,"pyProductVersion":"01.22.10"
,"pyRepositoryName":"DevOpsRep"
2018-08-16 14:28:49,447 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ Apex:01.22.01] (apper.Pega_Int_Pipeline.Action) INFO RXK1333 - Task execution completed for task : publish
Posting status to release manager system. Status object:
,"pyStatusMessage":"Internal processing error.** Application name cannot be blank\n.pyProductName: ** Application name cannot be blankUnable to open an instance using the given inputs: pxObjClass = \"Rule-Application\", pyProductName = \"\", pyProductVersion = \"\""
,"pyStatusValue":"FAIL"
Request object: {
2018-08-16 14:28:51,791 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ Apex:01.22.01] (apper.Pega_Int_Pipeline.Action) INFO RXK1333 - Task execution status published by doing call back for task name:publish
Http status code of call back:500
Sattus message of call back: the HTTP response code of 500 indicated a server error. The response data may contain a reason
