Configured PegaRules datasource does not have permission to view schema objects in RULES schema
How to assign the required privileges to the database user to view schema objects in RULES schema?
Hi @DericL67
Could you please check configuration for your Account. Please find example for Administrator account:
For view schema we required PegaRULES:DatabaseAdministrator priviledges.
Piotr
The permissions should be documented in the different installation guides.
You can start at at the link below then drill-down to get the guide which you need
https://community.pega.com/knowledgebase/products/platform?product_version=7071
I hope your question is specific to database user is not able to view schema objects ?
If yes what’s the Pega version your using with database details .
