Capgemini
Last activity: 11 Sep 2020 9:09 EDT
Why is Pega 7.4 data type creating external class/ table in CustomerData schema?
- Add a new/ existing data type using designer studio/ express data explorer
- Configure data type source by selecting key
- Save the data type
- now open the class created and do test connectivity
- it will show as obj-external class
- the table created as part of data type is not having pxObjClass/ pzInskey- This is obvious because it's external
- I have tried to give PegaData as DB while configuring source for Data type but it's showing error " Please select valid DB"
- I have tested this with brand new 7.4 instances and upgraded 7.4 instances. The result is same for both.
Is there any design change happened as part 7.4?
Is there any config missing ?
Updated: 11 Sep 2020 9:09 EDT
Capgemini
Mesh Link explaining more about this issue but it has limited access.
https://mesh.pega.com/message/334796#334796
Support Article regarding same SA-60573
https://community.pega.com/support/support-articles/unable-create-data-table-post-application-update
Hi Pandj,
Hi Pandj,
In Pega 7.4 version, We have a validation ( when rule ) in step 1 of "PegaAccel-Task-. pzCreateLocalDataStorage" activity not to use "PegaDATA" Database for Configuring source for Data types due to some Internal Constraints. It seems PEGA introduced the CustomerData database rule since PEGA 7.4 and when we create the Data Type rule, PEGA is by default adding px related properties. You can use "CustomerData" DB ( which is pointing to PegaDATA ) for Configuring source in Data types for System of Record.
Mihai Octavian Cernat Jayalakshmi Jagarlamudi Pramod_ Religent AVINASH L M
Saltech Consulting
What is the intended purpose of this new database / Schema? It seems to have customer database tables in it. I can see perhaps it may have been intended for some security or logical grouping but how does it then make sense to have the data types created in that?
KNS Dattabhishek
Rabobank
Is there any update for the reason of this change?
We are not planning to store any customer data but we do need to create some for configuration information. Is there a possible override to this? (Manual script execution for the creation of table in PegaDATA schema?)
Thanks.
Saltech Consulting
We ended up just commenting out the offending line by doing a private checkout. Clearly this isn't a long term solution.
Sourav Debnath
Also, when creating a product in 7.4 and trying to import in 7.3.1 an error is raised during import process about invalid CustomerData DB. Tried removing the DB-Name instance from package but did not help. Any idea how to work around this?
Capgemini
Saltech Consulting
I would like to understand why though? Its not ideal just saying 'we have moved something' without the rationale. Customer data is quite a misleading schema name also especially if you are dealing with customer service applications.
FYI, Now Pega relaxed the restriction to select only CustomerData when creating local data storage for Datatypes. In 8.1.2, it is fixed and you can create local storage for Datatypes in PegaDATA schema.
Syed Husain
Credit One
I created datatypes in CustomerData and want to move to PegaData, can anyone suggest how to do it?
Self
You can change the schema to Pegadata from the sources tab.
You can check the document attached .
This post might help you :
https://collaborate.pega.com/question/customer-schema-tables-no-ootb-columns
