Data object created in CustomerData schema vs PegaData schema
I have created a data object in App Studio and the data table is created in the CustomerData schema. I don't have an option to select primary key, no BLOB, no pzInsKey(not sure how obj methods works),no pxObjClass, no pxInsName and infact there is no option to change the schema to PegaData.
When I created a table from dev studio, I was able to change the schema. Now, it created the table with primary key selection, Blob, pzInsKey if I change it to PegaData schema.
I have two questions related to this.
1. I think to remove the technical selection, Pega might have removed these options in AppStudio. But again is there any way to default to one schema both for App Studio and Dev studio?? It might help.
2. What is the best practice in creating system of records? Which schema should be used to create the data objects?
Thanks in advance.doh
Nizam
