Difference between Process and Activity
what is the difference between process and activity
***Updated by moderator: Lochan to branch reply and create new post***
Process: Process defines how a unit of work (a work item) moves until it is completed (resolved). In Pega, a business process corresponds to a flow rule, which is associated with a work item. A flow may define many optional detours, side trips, and branches reflecting decisions reached along the way. The path that one item follows through the flow depends on its own requirements, automatic decisions in rules, and on available resources.
https://community.pega.com/process-overview/process-overview
Activity:In PEGA, an Activity is an instance of the Rule-Obj-Activity rule type. An activity is the fundamental sequential processing unit of the Process Commander system in PEGA
An activity when defined consists of a sequence of steps, each of which can contain a method or an instruction.
https://community.pega.com/introduction-activities/introduction-activities
Hope this helps.
