Widget in the Case Manager Dashboard
I have a requirement to display few widgets by default to all the operators in the dashboards.
Please guide me on how to achieve it?
In the dashboard, click on the settings gear icon and edit the dashboard as required and click on publish to default. Then same dashboard should be available to all users.
Tried that but it doesn't work
After making the changes and publish to default, when you login with other user to same portal, are you not seeing changes?
OR Are you importing your application to some other system and trying it.
If you are importing, you have to package System-User-Dashboard instance as well.
How to publish to default ?
what do you mean ? I can see only publish ahd publish to workgroup options.
How to make the widget visible by default to all the users who login?
Finally I found the publish to default which was hidden. But now I made the option to be visible for developers.
Now I clicked that option "publish to default", and logged in other end user but Widgets are not shown by default on login.
Could you please help me to understand why publish to default not working?
For your Info: I'm checking in the same environment.
Hi, please follow the following steps to the operators or access groups you want to show up widgets.
