Not Public Information
Last activity: 3 Aug 2018 4:17 EDT
pxCoveredCountOpen going negative
We have a situation that has been going on since 6.2, and with the upgrade to 7.2.2, we were hoping it would be resolved, however, it is still happening... We have a situation where upon attempting to resolve a case, an error is displayed because pxCoveredCountOpen has gone negative... For example, -3. I am a but puzzled as to how pxCoveredCountOpen could go negative. I could not find anything about this issue on the PDN.
Scott
Hi Scott,
Have you configured anywhere in the flow to reduce the count of pxCoveredCountOpen property or manually setting the status to Resolved-Completed? In that case, the property value is not updated immediately and there by leads to inconsistency.
By default, activity Work-Resolve is responsible for decreasing the pxCoveredCountOpen property value when a child case is resolved.
The Study Group
I am facing a similar issue. pxCoveredCountOpen is changing to -1. There is no direct reference to this property to increment/decrement from any application code (App RSVs). The status is being changed by calling OOTB Work-UpdateStatus.
I thought a constraint should have been in place out-of-the-box on the allowed range of this property (& other px related Case Managment OOTB properties).
Any leads/suggestions on this issue are appreciated.
Raghav
Hi Scott,
Can you share the error details.
Tata Consultancy Services
Hi Scott,
we have similar issue in our project, so we updated it to correct value by following steps mentioned in below screenshot.
This might help you.
Hi Folks, :-)
Thanks for the responses :-). I actually opened an SR for this, though as far as I know it has not been fixed. I am on a different team now so I am not directly involved at this point. I was not able to find anywhere in our app that these values were being set, and fully believed it to be a product defect. It is reassuring to find that others are also having this issue, and that reinforces in my mind that this is a product defect. While it is sporadic and only happens every once in a while, it is a problem. I have forwarded the information provided to my previous team. Thanks much for sharing! :-)
scott
Hi Scott,
Please let us know the SR# so that we may track it through this post and update the post for the resolution.
Thank you!
Apologies. I realize I misspoke on this one after checking my list of SRs. My intention was to file an SR after checking with the community to see if anyone else was experiencing the issue. Reason being I have filed several SRs which were withdrawn by Pega though the issues were quite serious because we were able to fix the cases through direct manipulation of the database or through an activity to repair the errors because they are issues which are sporadic and not easily reproducible.
No worries! Please let your previous team know that they can Subscribe to this discussion and dive right into it!
Viswa J
CollabPartnerz
Could you please check are you decrementing this value(pxCoveredCountOpen )
we are not.
thanks,
scott
