DSM : pzInteractionId having negative values
I am working on DSM and for some strategies, we are getting the value of pzInteractionId as a negative value. While the property definitely can hold negative values, is this correct ? Since it is not consistently negative for all strategies , wanted to check if this is a valid scenario and it is not due to the strategy being designed incorrectly.
The negative value might also be a problem if we use this to send data to downstream systems.
