Larsen & Toubro Ltd
Last activity: 23 May 2018 16:06 EDT
How to convert a Pagelist to text file? Each page record should appear in a separate line in text file
I have a requirement where I need to copy the Pagelist results into a text file. Each page result should appear in a separate line and the properties should be separated by pipe(||) delimiter.
For e.g if my pagelist has 2 records (lets say country, country_code and currency are the properties) then the text file should have both the records in the text file as below. Each property value is separated by || and each record is in separate row.
country || country_code || currency
Janmajay Adhikari
