Optimum Infosystem Pvt. Ltd.
Last activity: 10 Sep 2024 7:16 EDT
How to convert a Pagelist to text file? Each page record should appear in a separate line in text file and place it in repository.
This implementation I have done in two ways:
Approach 1:
a) I have browsed the data from DB table. [Here you can also use DT or DPage or Report Definition]
b) Loop thru each embedded page in pxResults.
c) Under the loop add step "property-set" and add below code:
Primary.EmpResData = Primary.EmpResData + .EmpID + " , " + .EmpName + " , " + .EmpDep + " , " + .EmpSal + "\n"
NOTE : Here in place of "Primary.EmpResData", you can take "param.xyz" or "Local variable"
d) In Pages & Classes :
D_pxNewFile = Embed-Repository-File
e) Add "property-set" out of the loop & in step page give "D_pxNewFile " then add below code:
.pyContents = @pxBase64Encode(Primary.EmpResData)
f) Take method called "Save-DataPage" and expand :
DataPage = D_pxNewFile
repositoryName = "MentionYourRepositoryName"
filePath = "MentionYourFilePathWhereYouWantToCreateFileInSideRepository"
Approach 2:
This approach also will be same as above only changes required in step "c"
c) use "Map-Structured" method and expand:
Direction : Map From Clipboard To Property
Map : Create one map structured rule where you have to mention all columns of a table which you want to fetch (column name will be map in Property, In Offset and Length you have to mention the required space for that particular property "you can check PDN for how to create it ")
Property : Param.XYZ
Now add another step below under loop and add method "Property-Set" :
Param.EmpData = Param.EmpData+Param.XYZ+"\r\n"
NOTE: All other steps will be same as above.
@KiranM16585101 you logged this as a Discussion, but this looks to be a product question as you seem to be asking. "How to convert a Pagelist to text file? "
it is not clear what undocumented product functionality you are trying to solve/ explain.
Please can you clarify what is scenario that this discussion solves which is not covered OOTB?
It might help to include screenshots and steps that you have followed from the documentation which did not help your requirement.
eg
Text File rules - Completing the Create, Save As, or Specialization form
