LTIMindtree
Last activity: 6 Feb 2019 8:52 EST
Interrogation of main frame screen opened in web browser
We have a requirement where we have to open a mainframe application session through a URL in web browser and enter few commands to navigate to different screens in the session.
We are using web version of Micro focus Reflection to open the main frame sessions
Generally If the main frame application is opened through the windows emulator then we can add the text adapter and by passing the session ID it will be easy to interrogate the fields in that particular session. But in our case the main frame application is opening in a web browser and we are not able to capture the session id hence we cannot follow the normal text adapter approach as the session ID is mandatory for that.
As the application is opened through web browser, we also tried to do the web interrogation to capture the fields in the main frame screen but still it’s not allowing to interrogate the fields.
Could anyone of you suggest if there is any alternative way to interrogate a main frame screen which is opened in web browser
