Alotaibi
Last activity: 6 May 2018 2:54 EDT
Issue with generate PDF
Hi Team
I have issue when I generate PDF it's generated with symbols instead of characters
Could you please help to resolve this.
Alotaibi
Hi Durge
I'm working on 7.3.1 version
I generate the PDF by calling (Section name + pxcreatorPDF ) inside the Utility smart shape in the flow <<
when the PDF is generated it's look like that <<Untitled1
note: I tried Smart Shape createPDF in the Flow and it doesn't work.
![](https://accounts.pega.com/sites/default/files/pega-user-image/195/REG-194812.png?source=PUMINIT)
Hi Ghaida,
Have you passed the pyPDFFontsDirectory parameter in the HTMLtoPDF activity?
Evita.
Alotaibi
yes Evita <<attached HTMLToPDF
Istvan Szepkuti
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689955000/fb5beff5-b767-4af1-bc21-b6b191818957.jpg?itok=93Ku_bna)
ANZ Banking Group Ltd
You are facing this issue because of the non-supported characters by the PDF generator.
Make sure the HTML stream you are passing to the HTML to PDF has all the supported character.
As ex. If you have a text which you want to pas to PDF generator, in that case, don't copy-paste text from the Word use notepad.
I think it will solve the issue.
Alotaibi
where can I pass the HTML stream?
Alotaibi
First I insert Utility in flow <<see attach " 1 "
then I called pxCreaterPDF and section name inside the Utility <<see attach "2"
I create the section using the auto generated HTML <<see attach "3"
in the label LApprovalS1 I used Arabic Language and it's appear like that <<see attach "4"
how can I solve this issue?
Butchaiah Chowdary Yarlagadda
DXC Luxoft
Refer the attached screenshots to check if the Property-Set Methods in the Actvities pxCreatePDF and PyAttachAsPDF has appropriate Parameters Set.
Nivetha
