Rulesware
SV
Last activity: 20 Apr 2018 12:40 EDT
ERROR During installation (Pega 7.3.1 - Posgresql - Tomcat) PLJAVA
During the installation I recive the next message
Encountered database error attempting to load UDF library onto PostgreSQL, clean schema before running again.
Exception in thread "main" org.postgresql.util.PSQLException: ERROR: cannot use PL/Java before successfully completing its setup
Hint: Check the log for messages closely preceding this one, detailing what step of setup failed and what will be needed, probably setting one of the "pljava." configuration variables, to complete the setup. If there is not enough help in the log, try again with different settings for "log_min_messages" or "log_error_verbosity".
I check again and again the setup in the postgresql.conf and are the next.
pljava.classpath='C:\\PostgreSQL\\9.6\\lib\\pljava.jar'
pljava.vmoptions='-Xms32M -Xmx64M -XX:ParallelGCThreads=2'
work_mem=5MB
pljava.libjvm_location = 'C:\\Program Files\\Java\\jdk1.8.0_171\\jre\\bin\\server\\jvm.dll'
pljava.jar location
work_mem=5MB
pljava.jar location
jvm.dll location
And all the environment variables has been defined
When I run the install.sql was executed with out problems... and when I run the PRPC_Setup and check the connection to the database is connected with out problems.. even the main pega installer create some tables, funtions and views.. after to 50 seconds.. the installation is stoped with the error that I show in the begin..
