Is the requestor count limit and maxthreads count same in tomcat node?
Hi Rambabu,
No, this is not the same. A requestor can have multiple threads operating at a time depending on the environment specifically processors or cores.
Since Java support multiple threading, the threads run in parallel and the CPU divides its time between multiple threads on which user has no control.
