Should I use Data Page to push structured input data to Connect SOAP?
Hello, I have set up a connect-SOAP integration, this connector is used to update data to service with a bunch of inputs, the inputs have structured properties (page list). Would be using Data Page with Connector source a better approach? if so, how to get inputs from work object? Data Page can't accept Page as parameter.
Should I just use Activity? Thanks.
