Ford Motors
Last activity: 13 Dec 2022 7:15 EST
Connect soap is not invoking the proper data...
I have created a service and an service activity to retrieve the particular name details from the local data storage when i run the case by entering the name.When am running the service activity it showing the correct details for the particular name.
But when am running the connect soap activity it not giving the expected response details and also while the case..?? When i hardcode the request it is resulting correct response but it showing same details for all the name in connect soap activity and if i use primary or pyWorkPage then also it is not working properly...
what would be the mistake??
Thank you so much @UjjwalShukla_GCS
Manikantan
