Full Text Search - Search Index Host Node Setting - Single Node
In the System search settings under the "Search Index Host Node Setting", we have to give the node and directory and node name.
My question is do we need to specify this row in a SINGLE node environment?
The info in the help is as follows : "Search Index Host Node Setting - In a multi-node cluster system, the Elasticsearch index files required for search may be hosted on one or more nodes."
If we don't give any path where would the index files be generated?
Further related-random questions :
- There is a DSS "indexing/explicitindexdir" to specify a path. Which value would take precedence while pega forms the index files?
- What is the significance of "initialization/explicittempdir" value in the prconfig file?
- While performing any search in DEV portal, a SOAP call with URL in the SearchSoapURI DSS is being used. What is this for?
TIA :)
