    Cognizant
Last activity: 22 Mar 2018 14:46 EDT
Is it necessary to configure gateway configuration console in Federated case management set up ?
I am using FCM to connect applications that are based on PRPC Version 7.3.1 and PRPC Version 7.2.1.
In FCM article it says "You need to configure the Pega Web Mashup gateway on all the systems that attempt to access remote cases."
another PDN article says "Pega Composite Gateway not required for Pega Web Mashup from pega v7.2.1 onwards"
Ref: https://docs.pega.com/configuring-and-publishing-federated-case-management-repository-data-fcm-712
