able to add new case
Hi
I am stuck in workflow window. Not able to add new case. Plz do ASAP
Hi
Hi @ankurv85,
Thanks for posting on PSC.
Could you please provide more description of the issue faced at your end? I could see a thumbnail attached but not able to open it. Do screen-shot depicting issue and logs as well capturing the event.
Asif
I am not able to create Cases
Do you have the access to create the case, can you please go through your operator's access role and verify the same.
Thanks.
i did not find any link to change the access role. plz check above screen shot which i have provided
check the below article as well:
https://collaborate.pega.com/question/user-lack-access-be-able-create-cases
If I use Change Stage under smart shapes or I use Subprocess then I am thinking that I will get almost same type of functionality. Please explain what is difference between Subprocess and Change Stage
