Maantic Inc
Last activity: 6 Mar 2018 6:20 EST
What is the use of effective date in Ruleset?
Hi, What is the use of effective date in ruleset?
Blue Rose Technology
As of now i dont think they use this field anywhere . as mentioned on PDN it is just for future use.
Hi John,
If you want to see where this property is being used then you can open the property pyRuleSetVersionEffectiveDate and check for its references which might give you some information.
Regards
Mahesh
ASN Bank
Effective Start Date |
This field is reserved for future use. |
Maantic Inc
In Pega version 6.1. I am able to restrict the rules execution by setting future date in effective date. Does it changed in pega 7?
Checked with our product specialists and came to know that till that time the ruleset is not considered if its even part of the application, so it will behave same in Pega 7 also.
Maantic Inc
When I give future date in pega 7.2.1, it picks rules from the ruleset. is it product bug?
Is your ruleset being checked-in and locked before you test this behavior? If so, then you can go ahead to raise the bug.
