Murex
LB
Last activity: 11 Dec 2019 15:11 EST
How to export a single rule from a ruleset?
All the tools provided in Pega Studios, allows the export of a rulset at the most granular level.
How can we from the designer, export / import only one single rule form the ruleset?
Thank you
Likes (1)
Vipin Hardiker -
Labb
Hey Erahal,
If you are talking about importing/exporting a single rule to another environment then you can create a product rule that only includes the rule instance you want and then import that JAR file.
Leigh
Comment by Leigh is correct . Step by Step instructions in case you need them
1. Create a new Product Rule -- provide any name ( Right click on Sysadmin-> Create -> Product)
Version - 01.01.01
2. On the rule, scroll down to "Individual instances to include"
Provide the label and key -- for the key -- provide the pzInsKey of the rule.
(The pzInsKey can be found by clicking on Actions->View XML-> and search for the pzInsKey)
3. Check "Allow unlocked ruleset versions)
"Save" the rule
Once you have the "Create Product file" button will be enabled and you should be able to download the jar
Rahul Choudhary
Murex
LB
Thanks for your answer, Unfortunately this doesn;t suit the need, as the rule name changes. I need this to try an export the reports in the custom reporting module in Pega. And each new report created and saved has a different name.
Thus a fixed product rule with a fixed name does not help
Any other suggestion?
Elie
Here is a document attached that shows the process.
Murex
LB
Any other suggestion? If the xml representation is actual the represenation of the rule, isn't there a way to actualy export / import this definition ?
Elie
Ernst & Young LLP
MT
Can you please elaborate on what you meant by 'Customer reporting module'?
Murex
LB
I attached an image showing the module in Pega Knowledge OOTB application.
These reports as you know are stored in a custom ruleset created under the advanced section of the application
Elie
Rahul Choudhary
