Accenture
Last activity: 19 Dec 2018 15:45 EST
Issue with the import command for PRPC 7.1.8v
Hi all,
We are using the Pega import command to import the product jar to the target server. In this process, we have updated the prpcutils.properties file with the required data base information and jar path. After running the command we are getting the following error:
[java] (!) Unable to use given database configuration
[java] (!) Unable to locate classes on filesystem
Any suggestions would be helpful and following is the log file.
Log file:
-import:
Hi all,
Log file:
-import:
