Intel
Last activity: 19 Feb 2018 21:56 EST
CMIS Connector shows only default repository
I'm using a CMIS connector in my application to connect to Alfresco.
The Test Connectivity for the end point configured works just fine. I tried telnet and ping from the server to the endpoint, and they are working as well.
When i login to alfresco using the browser URL, i'm able to navigate thru repositories and folders. And able to perform all file operations.
However, when I do a browse repository: it shows only -default-. It is not showing my repository which is visible in browser.
I have double checked authentication profile, and ensuring the account i use to connect has all necessary authentication.
How to navigate to my repository from the connector and configure that in connector.
Attached below is snapshot of CMIS connector showing default repository.
