Audience Error
i encountered this error when i open audience:
This segment has failed execution in the background due to the following error(s):
Unable to open segment data source within PopulateSegmentTable
i still new using PEGA Marketing;
appreciate your advised. Thank you
Vironica
Thank you for posting query in PDN.
Could you please let me know the Marketing and PRPC version at your end?
Is the issue happening when you are opening an already existing segment [which has already ran successfully] or which running a segment.
Could you please trace when you are run the segment and attach the tracer here.
May be you can also check in tracer at which step of activity PopulateSegmentTable [class:Rule-Obj-ReportDefinition-Segment , RS: PegaMKT-Engine], its failing.
Regards
Sibani Saidarsini
