Chhabra
Last activity: 8 Feb 2018 1:37 EST
Project Agents stopping in SMA after restart of Tomcat
We have noticed that every time we restart Tomcat, certain enabled agents in SMA which are project specific get stopped on their own. Is there a way we can make sure the agents remain in the same state as they were before restart? Does this require a change at the platform end or the client end?
Please advise.
Swedbank AB
SE
Hello Rashi,
Did you find anything over the logs?
Sincerely,
Pawan
Chhabra
No Pawan. We had a doubt that this is some config change that needs to be done by the project teams and not by the platform engineers. Please correct me if i am wrong? The advanced agents and listeners go down.
Also, what can be the reasons of this behavior?
Hello Rashi,
SMA works with extension capability of JMX .
SMA communicates PRPC with JMX mbeans .
So once your restarting the server that means SMA lost communication with Mbeans .
There are some agents like SystemCleaner, SystemPulse, SystemIndexer etc will keep running even after restart because system needs for some mandatory functionality .
If you have created custom agent/listener you need to start it manually after server restart there are no other ways to do it .
You can say it’s the feature of JMX .
Let me know if you have any other questions .
Arun
Chhabra
Hi Arun,
Thank you for responding.
Could you please tell me as to how do I have the same settings as SystemPulse, SystemCleaner etc. for user specific agents configured?
Thanks.
Chhabra
Any update?
Chhabra
Hi Everyone,
This information is needed as we are seeing the same issue in production environment.
Thanks.
How is your agent configured (can you provide screen shots)? Depending on this, I don't think that it should need to be started manually.
Chhabra
Hi Nick,
I have attached the screenshot.
Please advise.
Thanks.
