Could not find instance from KeyProvider
Could you please help on how to fix this issue?
Thanks.
Thanks.
The screenshots attached.
Usually that means that the key doesn't exist. How are you starting the Interaction and Activity. If you are starting the Activity with a different key than your Interaction key, then that would explain it.
