Node is not coming up in AES
Thanks for posting on PSC.
By node not coming up in AES, you mean to say that node isn't reflecting in AES Dashboard?
Have you configured prlogging.xml as per "AES_Node_Configuration_Guide_71"?
Share the PegaRULES logs of AES node as well as server logs for further investigation.
Refer this:
https://collaborate.pega.com/discussion/troubleshooting-deferred-write-operations
Verify all the checkpoints are configured correctly as per above document.
Hope it helps in isolating the root cause, kindly mark as answered if it does.
Asif
