Synechron
Last activity: 15 Dec 2017 11:06 EST
How to replace current window and show a new harness using an activity
Urgent Help Needed!!
The requirement is to replace the current window and show a new harness using an activity.
Please help me on this.
TIA :)
Can you try with @baseclass.Show-Harness activity to achieve your requirement.
Regards
Mahesh
Synechron
I have tried with Show-Harness and ReloadHarness, but its not working..
I does not replace the current window instead it stays on the same window.
You mean to say that it is opening in new window instead of replacing the current window content?
Synechron
No.. It was not showing any change on the screen.
So literally you mean to say that the harness itself not being launched right? If so then the issue might be with your way of calling the Show-Harness with parameters or trace it and see what is being called to get more information for us.
If you are doing this as part of an action set for an event (e.g., a click event), instead of trying to launch a harness from an activity, which may not work the way you expect, you may want to try doing a "Launch Harness" action from whatever event you are triggering, and call your activity there. Please refer to support article SA-24067.
You can have a look at the below discussion. Maybe it is helpful for you.
https://collaborate.pega.com/question/how-resolve-missing-stream-key-property-pyid
Looks like both the discussions are interlinked and @JnnanankurC can you confirm the other discussion resolution might have resolved this issue also.
