Converting correspondence rule to PDF
Can someone provide a sample configuration of converting a correspondence rule to PDF?
Thank you.
Thank you.
Hi Chow,
Thanks for posting on PSC.
I have found similar requirement on PDN,
Please follow steps to convert Correspondence rule to PDF,
1. Convert the correspondence rule to an HTML.
2. The output of the property-set-correspondence should be framed as an HTML ( read the outputfromcorr from clipboard page, use appendString(outputfromcorr) in Html stream.)
3. Then, the output of the property-set-HTML can be used as the input to HtmltoPDf.
You can refer it, for more detailed descriptions:-
https://pdn.pega.com/community/pega-product-support/question/how-convert-correpondence-rule-pdff
Hope it helps you in implementation, kindly notify.
Asif
