Accenture
SG
Last activity: 29 Jan 2018 6:08 EST
Campaign run failed
Have designed a SMS outbound campaign - a simple direct flow to trigger SMS to the segment audience. The run failed, and no specific reason was given. When checking "fixed correspondence" tab, saw the error desc: "** Caught javax.mail.SendFailedException: Invalid Addresses".
I'm not sure why it is referencing email, when the campaign run treatment is SMS. Is my campaign run failing got to do with the SMS settings?
Accenture
SG
Hi all
This is resolved via hotfix for PMC 7.22
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689954000/559e2ff0-3ac4-493b-88e5-9a40e6b41144.jpg?itok=0-CbBQdb)
Could you please check whether Test Connectivity in SMS landing Page is successful or not.
And could you please attach PegaRules log for this issue.
Sibani Saidarsini
Accenture
SG
Tested SMS connectivity, it was successful. Have also test sending out test SMS, it went through as well.
-SH
Ohk.
Could you please attach the logs and create Support request to investigate further the issue.
Regards
Sibani Saidarsini
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689951000/acf9b3f6-41e7-4ef2-9e55-8da39714b54f.jpg?itok=JYQYUbWS)
Hi SH,
Please let us know the SR ID once created. We will continue to track it and will follow-up this discussion with the resolution.
Thank you,
Accenture
SG
Hi all
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/2023-07/f7f35052-5e7d-4ed9-ada9-87594f1d3c63.png?itok=bz3Ms_gZ)
HI @ShiHuiT3! Thank you for updating your post with the resolution. Could you also share your SR ID that you used to obtain the hotfix?
Thank you!
Accenture
SG
Sure, it is SR-B97012
