Empyra.com Inc
Last activity: 23 May 2018 13:47 EDT
Local Action to show a modal window
I want to display a modal window with a simple message and a "ok" button on a button click. I have added a click event in which I am calling a local action. Please let me know which local action should I use to display a message and how to customize the message.
Likes (1)
vijaya bhaskarreddy -
1) Drag a button from the Basic menu in the section.
2) Configure a click event and add a local action as mentioned in screenshot (1.png)
3) Open this flow action & add a section(2.png).
4) In this section you can a drop a paragraph. You may use an OOTB paragraph rule or you can create a new one(3.png).
5) Now, in this paragraph rule, you can give your message.
6) You may also use a label as suggested earlier instead of a paragraph rule.
Please excuse me for the names used.
Rachit
BBX
CN
Empyra.com Inc
Thank you, It helped!!
Empyra.com Inc
Thank you for the response. I am very new to this. Can you please elaborate your answer. If possible, provide screenshot.
BBX
CN
Rachit
Empyra.com Inc
Thank you for the detailed explanation. It helped!!
J.P. Morgan Services India PVT Ltd
You can also quickly refer to UI Gallery for a sample of modal dialog configuration.
Vijetha Mulky Kamath
How do we build the UI where it should display as non modal window
