Last activity: 22 Nov 2017 2:22 EST
Environment Setup Failiure
I am unable to import the exercise environment C-751-EnvironmentSetup.zip.
Not all records are getting imported at the first step.
As a result I am unable to execute the exercise step
Change the strategy such that 4gTablet offer is only made to frequent callers, i.e. customers with the property FrequentCaller set to Yes.
a. Right click on the canvas, and from the group select component.
b. Connect the Generic proposition data component to the new component.
c. Open Filter’s property panel.
- Enter the name: Remove Infrequent Callers.
e. Using the expression editor add a filter condition: .
f. Click .
g. Connect the Filter and the two proposition data components, and to the .
Primary.FrequentCaller property is not being found.
