Veteran Careers First
Last activity: 7 Nov 2018 23:47 EST
Deploy/Migrate
How do I manually deploy/migrate code from one environment to the next higher environment.... (Dev to QA)
Hi Henry,
If you want to automate the process of deployment using Jenkins you can go through my blog as follows:
If you want to do it manually then you can create the Rule-Admin-Product rule using Designer Studio > Application > Distribution > package wizard to create the RAP file and import it into the another environment.
Note: Also you can use the command line utility prpcUtils or prpcServiceUtils if you want to choose command line way.
Regards
Mahesh
Do I select 'export' and then export each ruleset individually into separate jar files and then import them individually into the next higher environment.
Yes, you can click on Export button then enter the name of your zip file which will be downloaded, later you can import it into another environment.
There are different options.
And we have a few rulesets (framework, integration etc)
Do I export each 'ruleset' individually into separate jar files
If you want to export the entire application from one environment to another then you can choose the Application to include in the Product rule during the Package of application, so that the entire application will be exported. Also at the end you can click on Modify button to cross check what information has been included in the Product rule and modify according to your requirement.
Do you know of any PEGA help documentation or videos that further explains the ins and outs of deployment or perhaps even a step by step...
I am confused if I should select 'Export' to export jar files or select 'Package' to use the application packaging wizard.
Application Package wizard exports the complete application through this you will have more control over export process. You will get few extra screens in Package option where you can choose to select or deselect few rules. You can go through this documentation for better understanding.
Pt. Asuransi Sinar Mas
ID
I have the same problem. Now i use Pega 7.2.1, i think we have the difeerent menu here, and i am confused what menu i should choose,
can you lead me?
Thank you for posting your query in the PSC. This looks like an inactive post and hence, we suggest you create a new post for your query. Click on the Write Post button here. Once created, please reply back here with the URL of the new post.
