HCLTech
HCLTech
HCLTech
Posted: Nov 17, 2017
Last activity: Nov 17, 2017
Last activity: 17 Nov 2017 10:16 EST
getting Error while running BIX report and Data not inserted into table
when I run the BIX, i'm getting the below Error. Please find the the log and let us know any changes has to do in configuration.
- 00:05:16,411 [ OVADEVWEBSPHE01] (cluster.internal.PRClusterImpl) ERROR - Clustering has been disabled on this node by setting 'identification/cluster/protocol' to 'none', however the protocol currently being used by the cluster is 'hazelcast'. This inconsistency will cause functionality that uses the cluster to fail on this node and can lead to data consistency problems and potential data loss. This node should be shutdown and restarted with clustering enabled.
Thanks in Advance
Bhuveen
