Ootb activity
Hi... Can anyone let me know the procedure for creating case using ootb activity.
Thanks.
If OOTB UI Action -> 'Create new work' is completely ruled out, answer to this post lists a plenty of activities -
https://collaborate.pega.com/question/create-work-activity-launch-flow-work-object
You can use pxCreateTopCase activity.
Kiran.
You can have a look into Work-.pzCreateCase (This API is exposed in the palette in process modeler to create a top level/ sub cases within a flow.)
Regards
Mahesh
