HTTP 404 error - Page not found
Hi ,
My Pega Marketting virtual machine is starting up from Oracle Virtual Box and upon start-up and gives the message saying the Pega instance can be accessed on http:// Proprietary information hidden. However when I hit this URL I get the below 404 error. I tried doing a ping from windows command prompt to this IP address and the ping was successful. Does anyone know what's going wrong here ?
Not Found
HTTP Error 404. The requested resource is not found
Are you still experiencing the issue? Tomcat takes a few minutes to start before the URL is available.
Have you just downloaded the virtual image or has it worked before?
You may also consider using the cloud system which you can request directly from each practice what you learn lesson.
Paul
