Ruletronics
Last activity: 30 Oct 2017 6:18 EDT
USer specific case
Hi Team,
As part of my case i have created a case and it should only availble to the manager not the end user how can we restrict to the particular user?
Regards
Prasanth
Ruletronics
Can you help me how we place the security previlage so that i can configure in the access role of the particular user
You can have a look into this pega help prasanth for your understanding along with the links available at the bottom of shared help.
Ruletronics
can you help me the screen shot how we configure the previlage?
Prasanth
@PRASANTH, the above share link contains the sample configuration screen shots for your reference. In your case you need to go to Designer Studio > Org & Security > Access Manager and configure the FULL ACCESS to Open and Perform to the Manager and NO ACCESS to your end user, so that manager will have the access and end user will be restricted. Hope this might help you to achieve your requirement.
Ruletronics
Thanks Mahesh,
I have tried that approach but that doesnt work can you help me any other approach
Regards
Prasanth
Then you can try with the pyStartCase flow, where you can try to define the Start conditions and Security to define privilege as explained by Govardhan in the last comment of this post and see if it works.
Andrea Loris Gialain Mallikarjun Reddycherla
@PRASANTH - i had tried to implement your requirement with a sample use case and you can have a look into my attachment, so that it can be helpful for you to implement your exact requirement of restriction.
