Accenture Solutions Pvt Ltd
Issues in Interrogating Controls fo Java Swing application
whenever am trying to interrogate controls(Especially button,Menu items of virtual menu bar) of Java Swing Application.Controls are getting recreated & failing to match with the already interrogated(Same)control & getting an error -Control (name of particular control is not matched) while running automation.How ever Enabled UseKeys to the parent window of particular control & applied some match rules like Control children match rule &Window text ,position etx,but no luck.Please provide some resolution for this.
Pravallika
You will need to provide more information for us to assist you. We will need a full screenshot of the java application in view - with the control you are trying to interrogate. We will need screenshots of the list of properties for the interrogated control (Under the Match Rules Tab on the adapter) and what match rules you're currently using.
It would be best to single out one control at a time, so choose one that you want to debug and we'll attempt to assist.
