PL
Last activity: 23 Oct 2017 9:19 EDT
pxDateTime based date picker doesn't appear when filtering reports
I want to create a new report in Pega Marketing based on 7.2.1. When I drop onto the "Filtered by" area Date columns, which use deprecated UI controls the Date picker works as expected. However when I want to add a Date column with associated pxDateTime I only see an empty placeholder. Both cases point to the same pzCalendar final rule from the Pega-Reporting:07-10-09 class.
I have attached a screenshot. Either pxDateTime hasn't been thoroughly tested or I am missing something.
I believe, applying HFix-32198 could address the issue. Can you please try ?
Venkat
Hi Grzegorz,
Please let us know if you do log an SR for this and its ID. That way we can track it and follow-up this discussion with the resolution.
Thank you,
PL
Thanks Venkata! I'll see if that hotfix works and let you know.
Lochana, I haven't created the SR yet since I was wondering whether anyone in the community faced similar issue.
PL
I am having an issue with locating that HFix-32198. Has this been withdrawned? If not, where can I find it?
PL
Many thanks for your prompt reply. We've applied the hotfix and it resolved the issue.
That's awesome!
Marc Alderman
