Apple India Pvt Ltd
Moving Pega 7 cases to Pega 6 environments
We need to move services cases from pega 7.3 to pega 6.1 SP1. We can see there is an issue with blob.
Is there any other alternative to move cases from 7 to 6?
There is no mechanism out of the box that does this. If it is just the data, I assume you could recreate the cases via some script but that is not recommended. There are likely too many dependencies for the case to process correctly in that version. What is the reason for moving back to a previous version?
