![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689875000/cb80d47d-e4e8-47b8-bedb-9b3c42f08e0e.jpg?itok=rnR8AszO)
CGI
Cursor is moving to start of line, while typing
Issue: Cursor is moving to start of line, while typing in text area.
Requirement: If there is some value in Text Area, we have to enable Save button. Otherwise disable.
We are using Text Area and "Any Key" event with "Post Value" action. On Save button, we are client side disable condition.
Thanks in Advance...........
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689951000/acf9b3f6-41e7-4ef2-9e55-8da39714b54f.jpg?itok=JYQYUbWS)
Hello!
On reviewing the corresponding SR, we see that it has been resolved. SA-55131 was created as a result of the investigation. Please reference that if you have the same question.
Thank you,
![](https://accounts.pega.com/sites/default/files/pega-user-image/39/REG-38808.png?source=PUMINIT)
Have you tried onChange refresh section against the text area ?
CGI
We have tried onChange refresh section on Text Area. We have to click outside of the Text Area to trigger onChange event.
Hi
If the refresh happens on hover then it will go back to the beginning of the text. That is expected behavior.
Hence you have to opt for onChange refresh.
CGI
We are not using hover.
requirement: If user enter single character or value text area, button should be enabled. If there is no value in text area, button should be disabled.
Please share the solution.
How you want the user to access the button ?
1. Tab out of the text area and reach the button ?
2. Take the mouse control out of the text area to click the button ?
CGI
User enter the value in Text area and take the mouse to button for click.
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689979000/321c2db9-adc7-4c43-8f1d-d6a84c486e5a.jpg?itok=mEyE0RUn)
Hi Rajasekhar,
Had you gone through this discussion where we already discussed similar requirement.
Regards
Mahesh
Guangri Liang
CGI
Thanks for link.
In which Pega version the BUG-320375 is fixed?
Hi Rajasekhar,
I looked in to the internal portal and it lists that this BUG was fixed in the recently released Pega 7.3.1.
CGI
Thanks........
CGI
As you mentioned that this BUG was fixed in the recently released Pega 7.3.1.
We are using Pega 7.2.2. Can we know the details of fix to make a local changes in our code?
CGI
@Rajasekhar, to get more details on this fix i would suggest you to raise an SR with the Support team for further assistance.
CGI
Thanks it is helpful answer.
Client is not fine with javascript, asking for fix.
CGI
CGI
Try HFix-38507 for 7.2.2
May be that can help/
CGI
We will try and update........
CGI
We will raise SR and update
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/2023-07/f7f35052-5e7d-4ed9-ada9-87594f1d3c63.png?itok=bz3Ms_gZ)
CGI
SR-C21535
Hello!
Thank you,
